Nitrous, Super Chargers, & Turbos All charged talk about going FAST.
Going turbo-
Old Oct 22, 2006 | 12:45 PM
  #91
Default RE: Going turbo-
Looks great... What else do you want? Oh I know... n/m...
How does it run? You haven't even done a rundown on things... A review of how it's running would be nice. You might get more interest if there is more information. You stated 4+ days ago that you were going to the dyno in 2 days.... Did that happen? What did it pull? Have you had it tuned for 8psi yet?...
Old Oct 22, 2006 | 02:38 PM
  #92
02 Vortech's Avatar
02 Vortech is an unknown quantity at this point
ORIGINAL: swartlkk
yeah i know i couldnt get 2 shop in time 2 get my TB welded thus no dyno- have it scheduled for tuesday for 8psi- getting dyno numbers- it runs great- drives like stock until i get into it- getting 21mpg @ the least the first two full fill ups- its reliable- does fine in the rain- i have moved the filter above the frame rail so its different then last time-
Old Oct 22, 2006 | 08:42 PM
  #93
jagblazer01's Avatar
dude the video is awsome....cant wait to see some numbers from the tuning and bumping up the boost
Old Oct 22, 2006 | 10:03 PM
  #94
EkStreem G's Avatar
EkStreem G is an unknown quantity at this point
Wow, it sounds nice as sh**! It's about time you get that grille back on....lol. Wut are gonna do about that turn signal/I.C. piping clearance problem?
Old Oct 24, 2006 | 04:24 PM
  #95
02 Vortech's Avatar
those corner lights still work- i just had to notch them 2 fit the intercooler piping i still think it looks great im gonna take alot of picture of the underside of the truck 2day- i will post them up in about an hour- get an idle video and some other stuff- over time i will give you the pro's and cons- and then the kit will be up for sale sometime next year- i will be refining it through out the time it is on the truck- im buying a 5.3L gonna put LS6 heads on, G5X3 turbo cam, 8.5:1 compression, GT76 turbo, intercooled, th400transmission- gonna be a monster- wanna turn it into a supra slayer
Old Oct 25, 2006 | 11:10 AM
  #96
offroaddude77's Avatar
offroaddude77 is an unknown quantity at this point
ORIGINAL: 02 Vortech
ORIGINAL: offroaddude77
mach isnt using a stock spider thats y i asked.
yes they are......... beleive me every boosted s10 or blazer on s10forum would have an upgraded spider injection if there was an upgrade- mach doesnt have a custom mpfi on his truck. thats with the FMU and fuel pump and sometuning he hit those numbers
Your setup turned out pretty good... i like it. However Mach's #'s are wrong. When mach ran his blazer the turbo was WAY to small. He has changed the setup on that blazer like 4 times. Mach is local for me, he tuned my blazer, and is helping us with our hopefully 1000 h.p. syclone build. I will p.m. u the rest i dont want what im going to say getting in to the wrong hands...
Old Oct 25, 2006 | 11:13 AM
  #97
02 Vortech's Avatar
sounds good- the stock block can only handle 400whp usually tune has to be perfect- hes making more hp now on a bigger turbo? how big was the turbo he was on @ 360whp?
Old Oct 25, 2006 | 11:28 AM
  #98
yeah Katech is build our motor and block. http://www.katechengines.com/katech_inc/
i dont know what those numbers are from, Maybe his twin turbo setup, he doesnt say. He is making more Now tho.
Old Oct 25, 2006 | 12:32 PM
  #99
02 Vortech's Avatar
there is a guy on s10forum making 402whp on stock spider- hes using the procharger FMU and inline fuel pump- so im not to worried- i will try and max out the 4.3L once i get ready for the 5.3L swap- see if she can take 400+whp for a while....
Old Oct 25, 2006 | 01:10 PM
  #100
yeah u will be fine as long as u have enough pressure which u do probably so ur good, also as long as ur spider isnt one of the defective ones like mine is and needs to be replaced.
