Looking to buy a Code Scanner
Old 01-15-2011, 08:57 PM
grantd's Avatar
grantd is on a distinguished road
Default Looking to buy a Code Scanner
I am looking to buy a code scanner. I have A 1995 4x4 Chevy Blazer I am wonder if this is the right one for my truck and if anyone knows if it is a good one. http://www.amazon.com/gp/product/B00...A1IONBBRHLTCBR
Thank You,
Dustin
Old 01-15-2011, 09:21 PM
ABN31B's Avatar
seing as how you are a 95, you fall in a really bad spot for this. your truck might work with OBDII, but might also be what is lovingly called OBD1.5...
Best way to check would be to look at your PCM. you could also go to an Autozone or similar parts place and borrow their scanner. if their OBDII works with yours, you're good (and lucky). If not you're in a rougher spot as it is tough to find support for your diagnostics system...
heres a snippet from a similar situation:
Originally Posted by swartlkk
There were two computers used in the '95 model year that came with the OBD2 style plug. Only the one with the PCM located on the passenger fender under the hood is completely OBD2 compliant.
If the PCM is not on the passenger inner fender, then the system is OBD1.5 and requires a special scan tool to read the OBD2 type codes. OBD1 type codes can still be read using the paper clip method.
heres a link to some help if you're a 1.5
Old 01-15-2011, 09:22 PM
AJBert's Avatar
'95 is a tricky year as early in the build was OBDI, middle was OBDI.5 and the end of the year was OBDII. If yours was built late in the year and IS OBDII, then this scanner will work for you.
Now you just need to figure out if you have OBDII or not.
EDIT: Beat again!!! lol
Old 01-15-2011, 09:36 PM
ABN31B's Avatar
Old 01-17-2011, 01:34 PM
grantd's Avatar
Smile Thanks
Thanks for your help. I really do appreciate it. Sounds like you guys really know your stuff. Thanks again!
Dustin
No false Bravada
04-15-2015 04:04 PM
big_charms@hotmail.com
03-25-2013 08:12 PM
bizzs
11-04-2012 02:11 PM
mikekolb
07-26-2009 11:59 PM
95LS
04-13-2008 11:27 PM
Quick Reply: Looking to buy a Code Scanner
